Has anyone tried using one of the snap cases such as the rubberized one after installing a full body skin such as bodyguardz or the zagg? I would like to know if it fits.
I tried one of the screen protectors from the Sprint store and it was pretty bad. You have to cut it to fit and it doesn't look good on the phone. I am using the gel case they sell at Best Buy and it is great. It costs $19.99 for one and they sell for $19.99 for 2 at the Sprint store but the one at Best Buy is much rubbery. It almost sticks to your hand making it less likely to drop.
I have a full bodyguardz on my phone. I had thought about putting it in the rubberized case but I found out it will not snap shut. It did fit when I had just the screen protector on it.
