Accessories cases for droid 2 with extended battery
chrisjm00
I have a quick question. I have a droid 2 with an extended battery. What I want to know are there any cases that fit the phone without removing the battery door? I don't have a problem taking it off if it wont do any damage to the case.
I just got my D2 a couple weeks ago w/extended battery and would also like to know if anyone knows what cases will fit with it.
I was at the Verizon store over the weekend and picked up one of their 2 piece hard cases. They make one for extd. battery and if you use the std battery it will work find. The only drawback is its a real PITA to remove when you need to get into the battery or memory card. I know others say you can get them online for cheap, but I only found the style for the std battery (Verizon charges $24.99)
