Is it just me or are there no cases once you get an extended battery. Sendo adds 4mm and the OEM adds 1mm. I am guessing that you have the choice between the battery or a case.
I wonder if a flexible case like the tough case would have a problem with a 1mm difference.
Sent from my Incredible using Tapatalk
