Catchup tv works on the X10
funny that.. when i goto that site on my phone it tells me i need flash 10 installed.. tvcatchup.com??? lets have the url then? as that one doesn't work.
there was/is an app called Myplayer which will stream or download BBC 'catch up' programs, currently for some reason this has vanished from the market, or for me it has.
there is also Yamgo which is a URL based Live TV streamer, google it.
Those both in UK.
Hi all, it works on mine and has done since the soccer world cup, as that was the target time that tvcatchup had indicated (for android).
When u search for Tv catchup put in "tvcatchup mobile". If you just search tvcatchup u will be unable to view. Good luck. If u cannot get it Ill go through motions and give better detail tomoz but DEFINATELY works on X10.
