wolfdogg
Member
i have installed CCM7_Eris_V24_RIP
text messaging will not work for me, we have called verizon and they couldnt find the problem, so im pretty sure its in the install, however we did activate the text messaging after the install, where before using another CCM7 mod i hadnt had it for some time, but it did work in the past on that mod.
there is no way to mount the usb sd card, the mount and unmount found in the menu only mounts the sd card to the phone, but when i plug in the cable to the computer, i dont get a message in the slider menu to mount. I cant offload my pictures at all without plugging in the memory card to an sd reader wtih an adapter.
the system is very slow, pictures take about 5 seconds to take each for example. i know the upgrade is probably a bit much for the Eris as far as new apps vs what the processor can handle, but its real sluggish when navigating through the menus, etc...
i need a faster build, and a recommendation since i cant text message, connect usb, and operate the phone with ease.
