Root [CDMA] Custom Splash Screen CyanogenMod 7.1
Meen27B
I have an evo 3d with cyanogenmod 7.1 rom installed. I also have twrp recovery installed. Right now I am trying to flash a custom splash screen but I don't know what "android-info.txt" file I need. Please help.
You don't need to flash the bootanimation.zip. Actually, if it's called that, you can't flash it. You just stick it in the right folder and it should work on the next reboot. I think for CM7, it'll be in /system/media.
Do you know how to use a root explorer app?
