Root [CDMA] Help!! Root evo 3d after update??
ramosk6
is it possible to root evo 3d after the ics update sprint sent out? i have a mac and i need a step by step guide on how to do this since i am new to rooting.
Hello, you seem to have posted this in the warp section.I will get this moved to evo 3d land for you to get some responses from others with your device
I would also like to know if there is a way to do this. I downloaded the OTA expecting I could live without root for a while until the new version is rootable, but it turns out I really need wifi-tether for work this weekend. Hopefully there is a way to root after this update!
Edit: I just read something about HTCDev unlocking the bootloader. Does that allow apps to have root access? Would I have to flash a different ROM?
HTC dev will do a factory reset on your device, allow you to put on a custom recovery, and gain su access.
With HTC dev there are usually some quirks that full s-off users don't have to worry about, so I would wait for instructions from a fellow 3d user before proceeding
Aw man, I didn't want to do a reset. Hopefully someone on here has some other options!
I merged your 2 threads together since they are both related, I would help you now but I have to run, but I will give you a thread to to read in the meantime, the only issue is I am not sure if it applies to the same since the new ICS update, I have not heard of other rooting since the new OTA update, see thread below.
Sticky: Complete Newbie's Guide to rooting and flashing Evo 3D ROMs/Kernels using fastboot (
1 2 3 ... Last Page)
