Root [CDMA] Lollipop for Boost Moto G
So are there any custom roms for the boost mobile moto g out there that you can tell me about?
For me I've found PA 4.6 beta6 stable enough for a daily driver, some people like slim, cm and crdroid. The deodexed stock ROM is very nice with some xposed modules. Really its just up to you and what you want from the rom, these are all 4.4.4 roms by the way.
Cool, thanks. And do these have working radio and antenna?
Lollipop Roms are the only ones that do not have radio and data. All of the KitKat Roms mentioned above should be fine. Some have issues with MMS texting but there is a flashable fix you will find with most ROM downloads
