Root [CDMA] Need help getting S-ON
7)Now plug your device in, and navigate to the fastboot setting from the menu and select it(power button)
8)Open CMD with the fastboot files in with the adb files
9)Run the command "fastboot oem writesecureflag 3" without quotes
10)You should now be 100% stock unrooted and s-on!
I'll take a shot at it. 7 and 8 can be reversed and combined.
Plug the phone in. Go to your sdk platform-tools folder and shift+right click. Click "Open command prompt here. type "adb reboot bootloader" and hit enter. Then when the phone boots up use the arrow keys on the phone to navigate to fastboot and then hit the power button to select it.
Now follow step 9 exactly as it says and you should be good to go.
