Root [CDMA] [Q] Help, can't get into recovery mode :(
hi all...
i have a problem with a recovery mode via bootloader. i cannot execute all options menu inside. as usual to access the bootloader, plug out the battery and plug back in, volume down + power, in the bootloader i choose recovery. so i'm in and choose one of the menu for exp; Power Down, or Backup/Restore, or any option but nothing could happened. it only stuck without any progress indications, just show me a background CWM Wallpaper. But if i press the power button it back to main menu. Press the power button again at the selected menu (Reboot for Exp), nothing happened..
for your informations;
- 3VO GSM Version
- hboot 1.49000011
- S-On
- rooted
at the first time i was thought it has something with a ROM Manager which i've got from the market, so i uninstalled it, and still same. Recovery is stuck and not responding...
please help, why my recovery wouldn't work and run properly? is there any solution for this problem?
Thank You in advanced..
