Like to bet its rooted sounds like the recovery bug.....
Int
leave it plugged in for a few hours and dont touch it.
Agree with xs....sounds Luke that battery is Very dead
I disagree the phone cant be more than 12 months old, far too new to have a dead battery, my bet is STILL on the recovery bug...
Try installing the hboot drivers on pc and leave it plugged in, cant see it working but worth a try....
Int
To see if it's a recovery issue, you can buy a $5 wall charger off of a site like buy.com, pull the battery out, and charge it via the wall charger.
If the phone boots, it's because you have the recovery bug and we just need to flash a new recovery. If the battery doesn't take a charge, it's a bad battery, get a new one. If it doesn't boot, it may be that someone temp bricked it to try the downgrade. If it's the downgrade problem, then don't worry, there are ways of recovering it.
But we really need to know which problem you have. Get the wall charger and try to charge up your battery.
