abh2
hi i am user moto g boostmobile xt 1031
I don't really know where to post it .so, I decided to create a new thread for this..
i want to share for upgrade stock rom 4.4.4 verizon, and it work on my device moto g boostmobile
requirement :
- must unlocked bootloader, unlocked bootloader, and unlocked bootloader first, do not do if your device locked boot loader!! ( see https://motorola-global-portal.custhelp.com/app/standalone/bootloader/unlock-your-device-a )
- must installed motorola usb driver, Download and install Motorola Drivers see ( http://www.mymotocast.com/download/MDM?platform=windows )
- Download and extract the stock firmware 4.4.4 verizon from:
FileFactory or Motorola Firmwares, after extract it, copy files on windows folder ( it contain minimal adb) paste them into nto the same folder as the stock firmware files (the same folder as the .bin and .img files).
- because this is .xml.zip file, downnload http://dl-1.va.us.xda-developers.co....zip?key=JK9p-9CY8ScEsBoZPbrUnw&ts=1407339670 and extract the .exe into the same folder as the stock firmware files (the same folder as the .bin and .img files).
- must usb debbuging on, power off the device, hold power and vol- for a while until enter to bootloader, connect your device to pc
- find the script .bat, open and wait until it done... and reboot maunally
- congratulation your device on stock 4.4.4 verizon
***after flashing stock verizon 4.4.4 you will lost signal and no data, no call no text, because it write prl from verizon, you just write prl with the correct provider that u used with DFS software, done
for rooting and install costum recovery just choose costum recovery what you prefer, cwm or twrp, go this link for download http://androidforums.com/cdma-moto-...kernels-roms-more-boostmobile-05-04-14-a.html
and flash supersu.zip in costom recovery, go this link [2014.07.27] SuperSU v2.02 | Android | XDA Forum
- for remove bloatware from verizon just download and install titanium back up, do carefully about system app from verizon, not all verizon app is bloatware
----- if you like mods unlock ring just follow original thread on xda -----
here the link [MOD] "M" unlocked ring | Moto G | XDA Forum
here pic attached to this post
i'm sorry for my bad english, if i break the rule in this forum, pm me, and i will edit this post, thank you :smokingsomb:
requirement :
