Root [CDMA] Will pay for tweak
Lilg37
Ok I've asked and asked and asked, can not for the life of me get ahold of the right dev or pointed in the right direction.
I want to be able to build a tweak or have a tweak built to where I can bring my notification bar from the top of my phone, to the very bottom of my phone. So that instead of reaching all the way up to the top I can just pull it up from the bottom.
I've seen a hand full of people who agree they would use the tweak if it were available.
I know this is possible BC I had it on my photon with cm7
I just really wana build it with some help or have someone do it, I will gladly donate to the dev.
Please and thank you
Have you checked the market for 3rd party apps, also have you tried sending a PM to a dev, I would assume this would not be easy to do, but I am sure you could always ask them directly, I would send a PM to Scott from Scott Roms, or Mikey from Mikeyxda, they might want to do it, but might be able to direct you in the right direction. You could also sent en email to some of the app devs from the market and see if that would be something they would like to take on. either way you would have to use the top if it is not for notification, so to me it defeats the point IMO, drag up or drag down.
The notifications are all pretty easy to reach, it is the bar itself that exceeds the length of my thumb and makes it a little difficult
Check out the xda forums for cdma development. Joelz's cm9 thread has a link to something he calls tablet mode that does just that. It makes your font a bit smaller so some people didn't like that.
Go Launcher gives you the option to swipe down anywhere on the screen and bring the notification bar down. I believe you can change the gesture to make it so that the bar comes down when you swipe up.
