Help cell is frozen
  • Start date Start date
A
Android Question
Guest
The cel is a LG Leon LTE running lolipop 5.0 Model LG MS345 of Metro PCS
I was tring to root the cel following the instruccions on this forum posted and to the end off
the operation the cel just went to metro pcs screen and do not does nothing no even turn off
I let the battery die and restar holding power and volum buttons same result
Help please
Can you provide a link to the recipe you used, then tell us exactly what you did ("I followed the instructions" doesn't tell us if you missed something or did something wrong)?
The best bet, however, would be to post the question in our LG Leon root forum. The reason is that this stuff is usually device-specific, so you'll get the best advice from people who are familiar with that device and the tools for rooting and flashing it, and they are most likely to see your question if it is posted there. I could move this thread, but since they will probably have questions for you, and so you'll need to register anyway to answer them, it might be simpler for you to post a new thread, with as much information as you can, in there.
