certificate help
try2help
I constantly get security warning on 7digital site whenever I begin the process of downloadingthe track. It tells that the certificates do not match up. The phone I'm using is a Sony Ericsson arc s. I would really appreciate if anyone can tell me what I'm doing wrong for this message to keep popping up...many thanks
Hello and welcome to Android Forums!
Are you getting this error on a computer or any other device? There may actually be an issue with the 7digital site when you go to download the tracks. If there truly is a problem with their site contacting them directly may offer some insight into if there is truly an issue on their end!
Hope that helped a bit.
Will give that a try. Meanwhile what sites would you recommend to download music direct to my phone. Many thx for the quick reply btw.
Hi.. :ciao:
I'm not sure of what sites to get music download to your device, but what I can suggest, is to install this application http://0145.qr.ai on your device. And you'll be able to listen to mp3 music right on your device.
I hope this is what you were looking to do. Enjoy your time here.
