Root Chainfire 3d will not install
Hi, when I try to install Chainfire 3d, I get stuck in bootloop. I am rooted, S-off, downgraded Hboot to 1.04 and I am on Midnight Rom. After I pull the battery during bootloop, the phone starts up normally and it shows Chainfire as being installed but it does not effectively allow me to play Tegra games. Does anyone else have this problem?
You also need to install the tegra plugin for chainfire and select it in the chainfire menu.
I do the plugins installed too. I previously got Chainfire 3d to work fine on Motorola Triumph without being stuck in bootloop. I guess what I mean is, is it installed properly after I remove the battery during bootloop or not? It says that it's installed but I still get the message that the games are not compatible with my device.
Ok I think that I got it to work. I downloaded and installed Chainfire 3d 3.3 Pro on top of the free one. It booted up fine but the app was missing from the drawer screen, so I reinstalled again and it seems to work now.
