Help Challenge with muting Defy when unlocking
MrDavo69
Hi All,
I have a Motorola Defy, with Telstra (Australian Telecommunications company).
The front screen of my Defy has a "slider" that allows for unlocking of the phone. On the left hand side of the "slider" is a little lock icon, and on the right side of the "slider" is a little speaker icon.
If I slide perfectly from left to right, e.g.: from the lock icon toward the speaker icon, the phone unlocks fine and works as normal. However if I accidentally swipe from right to left, e.g.: from the speaker icon to the lock icon, the phone goes into mute mode. Then when I successfully unlock the phone sound is turned off. This usually leads me to lock and unlock the phone again, in order to restore volume.
I have looked over the settings and there doesn't appear to be any way of removing the speaker icon.
If anybody knows how to remove the speaker icon or otherwise provide a solution to my dilemma please let me know.
Thanks for your help.
Kind Regards,
Davo
I think that the speaker on the lock screen is part of Android.
The other way to change the sound is through the sound option in Settings. I usually just turn it off and on myself. Seems like the easiest thing is to get use to not sliding right to left......
