Change default 'dock' applications on GS3
Lee_1011
Hi,
I have a Galaxy S3 running Jelly Bean, and I'm wondering if it is possible to change the default 'dock' apps - that is the apps at the bottom of ALL my home screens. The default apps are Phone, Contacts, Messaging, Internet and Apps.
Thanks!
Lee
Heya welcome to AF.
IIRC, you just drag and drop icons onto the dock, no? (I switched to Nova launcher a while ago, so stock may be different.)
BTW, there is an S3-specific forum you may be interested in as well:
Samsung Galaxy S3 - Android Forums
Unfortunately the drag & drop doesn't work. I searched google and it seems like they might have changed how it's done in 4.1, as none of the methods that came up worked.
Thanks, I'm sure that S3 forum will come in handy :)
