change default location avd
debittoo
Well i've spent more than 2 weeks trying to installing Android SDK+eclipse on windows 7 64bits
I did it more than 30 times? ><
Well i realized the problem is in the default location avd.
My defaul location is: C:\&#12518;&#12540;&#12470;&#12540;\&#12487;&#12499;&#12483;&#12488;\.android\avd (looks like the windows japanese version don't feet on android language, or maybe the haven't made it yet to work on this version, i'm not sure)
and i would like to change it to c:\android\.android\avd
i know there is some command i can insert in the file .ini of my avd but i don't know how....
can anyone help me?
I really need fix it ><u
Bueno al final pude resolver el problema era problema de las variables, y al parecer no se modifican asi como asi sino que tienes que reiniciar...asi que bueno...despues de haber tirado dos semanas a la basura pues..ya he podido hacer reiniciar el android 2.3 ^^
