You need to download from the Market some free ringtones, like " funny ringtones " for example. Once it's on your applications, open it, select a ringtone you like, long press on it,
and a window will pop up asking you wherdo you weant to use it . nitifications, messagge or
phone ringtone. You may have as many downloaded ringtones as you like, and they all basically work the same way.
