Help Change lock screen weather widget?
Hello all,
I recently did the jelly bean update and I am quite impressed with it. I noticed that it gives you the ability to put a weather widget on your lock screen. Is there anyway to change which widget it uses? I really like the stock accuweather widget that has the clock/time and date/temp and the little land scape that visually shows the weather. Is it possible to put that on the lock screen instead of the one that the S3 puts there by default?
Thanks!
