Yep
Eight different dictionaries: 380MB
Wasn't relevant to mention, but I have a second dictionary app data that I keep on the same folder, even tought this one supports folder changing, adding more 400 MB... french, italian, german...
You know
I was following EarlyMon's orientations, but I gave up
Whatever I find on threads is people that want to move their apps to SD. Apps whose data stay on the android/data folder (which, if I'm interpreting correctly, is the android standard... something like Program Files (x86))
Their cases are different than mine because the data read by those apps is not stuffed into some folders like
com.colordict. NO, it's a completely mobile/portable folder
And that's the reason why Links2SD won't detect any data
Or yet, I find people willing to completely invert the SD/internal logic
All these threads present the same solution: FolderMount and Links2SD
Which I'm still struggling on the use, but losing patience
FolderMount and my file explorers are unable to handle the sdext2 partition, the place I want files to go.
I'm still investingating if I created this partition correctly... or even if my root is not rooted...
UPDATE:
Now I got to think that I had no reason to put stuff on sdext2
And indeed: FolderMount works shiny and perfectly on the normal SD
Yay !
Now I only need a way to make these mounting points / symbolic links permanent (no need to rely on a apk)
My problem is almost solved
