change Search engine
  • Start date Start date
A
Android Question
Guest
I despise Google search, and would like to use something else for a search engine on my Andriod phone. I found one suggestion to change it, but have no "advanced settings" as suggested, does anyone know where I can change my engine.
Hi
You could install duckduckgo from the play store - it does not attract the adds.
If you use a different browser (to the stock android or Chrome) eg Naked Browser or Boat or Dolphin etc, you can select which search engine it uses by default.
Roger
