ftbmynameis
Hi guys,
I have an issue with my app:
I try to change the color based on my theme. My TextView is using color-selector with different states for enabled and disabled and I want to use my theme based color in this selector.
I have followed this solution: http://stackoverflow.com/questions/12703757/android-themes-defining-colours-in-custom-themes
My selector used as android:textColor in my view looks like this:
<?xml version="1.0" encoding="utf-8"?>
<selector xmlns:android="http://schemas.android.com/apk/res/android">
<item android:state_enabled="true" android:color="#ffffff" />
<item android:state_enabled="false" android:color="?attr/ThemeTest"/>
</selector>
with ThemeTest being my custom attribut which has a color assigned in my themes. If I use this selector as my textColor, the color is actually not what I picked but just a simple plain RED! HOWEVER if I use the custom attribut directly in my view
android:textColor="?ThemeTest"
then it works but I obviously want to do this based on the change of state of my view...
Does anybody understand this behaviour and know how to fix it? Thanks in advance!
btw: I have posted that question on stackoverflow as well but it didnt get any attention so far thats why I repost it here in hope someone is able to help me out
thanks a lot,
ftb
</selector>
thanks a lot,
ftb
