Help Changed Home Screen
timg
My home screen has changed to where there are 4 buttons across the bottom of the screen. I cannot get my phone back to the way it worked originally , don't know why it changed either anyone with help would be apprieciated, thanks
Tim:(
4 buttons on the bottom?? do you mean like 4 shortcuts or widgets?
Hi 4 shortcuts , ive repaired my phone & got back my original screen , but quite afew things arnt on any more so will try again later on .
Thanks for the replys
Tim
Tim
The home screen is customizable long press on an empty area and you can add/remove stuff.
I'm suspecting that he changed his homescreen to Timescape, where the 4 buttons on the bottom cannot be changed and the top part is the different tabs when you enter Timescape.
Just so peeps know you can change the 4 buttons at the bottom of the timescape homescreen by pressing and dragging one of the icons from the bar into the main list and then drag from the list into the bar the app of your choice. You can also re-arrange the order of icons in the main list to put more frequently used things nearer the top and hide anything you dont use at the bottom by just pressing and dragging them about :)
Hi Guys,
Ive just rooted my phone. Ran the cleanup cmd (and removed moxier and some other stuffand now my home screen has reverted to timescape. How can I get my screen back to home screen, with the 3 different homescreen (One to the left and right of the 'main' home screen...
Thanks a mill,
Lee
