Help Changing default programs.
ayrshiredude
Is it possible to change the program that is accessed when you select one of the 4 bottom buttons? I use Handcent sms and would like to be able to click the message icon and Handcent opens up rather then The samsung one. Is this possible?
I *think* you can do this if you install LauncherPro, or another dock style app, onto the phone.
You can change the icons in the dock.
Open the application drawer, hit the menu button then choose 'Edit'.
You can then drag icons to or from the dock (You can't get rid of the Apps/Home one though).
