Changing Icons on Lock Screen with JB
CharlieD
I use Handcent rather than the stock text app, mainly due to the ability to have different notification tones for different users.
Back in the ICS days one could go to the manage apps screen and disable the stock text app. Handcent also has a setting to make it the default text app. This would cause the stock text app icon on the lock screen to be replaced with the Handcent icon.
With JB, this no longer works. Handcent still has the setting. However, going to the stock text app in the manage apps screen, the disable button is greyed out. So, the stock text icon is still on the lock screen. Is there a way to replace it in JB like there was in ICS? I can't seem to find a way and I didn't find anyone else complaining about this here. Am I missing something?
Thanks,
Charlie
Do you have the latest update for handcent? I'm not sure why or how, but my icon on the JB lock screen shows the Handcent icon and it takes me to Handcent.
Yes, I do. No updates listed in play store.
Can you disable the stock text app or is yours greyed out like mine?
I dunno what else to suggest..have you rebooted the phone? Cleared cache on Handcent? Do you have a cache clearing app? Maybe try clearing all cache...Lastly...tried uninstalling and reinstalling Handcent (after doing a Handcent backup)?
Had already rebooted. I do have a cache cleaning app. Ran that and cleared everything. No change. Deleted handcent. Reinstalled. No change. I must be missing something (and yes, I did an FDR a week or so after the JB upgrade.)
if you went into the stock app, cleared defaults, and went into handcent and MADE it the default and it didn't change, then i don't know what to tell you.
the only other way i know of to change it was by rooting and freezing the stock app.
