Changing Input
kturcotte
I have a bluetooth controller for games, and I'd like to setup a task for when I launch those apps, but I'm not sure how. What I need Tasker to do when I launch the particular game apps is to turn in bluetooth and pair with the controller, and then set the controller as the default input device (As opposed to the keyboard). Once I exit the app (Either by exiting through the app's menus or just pushing the home key), I need it to reverse everything to how it was before I entered the app. How/can I do this? Thanks!
Try this:
New profile: Games
Context: application - select the first game
Task: +net - bluetooth /set on
New profile: controller
Context: state - net - bluetooth connected
Task: input - input method
You would need multiple copies of the first profile, one for each game, but that should give you a starting point.
