Very easy to do...tap the + in the upper right corner to add to the desktop, tap Wallpapers, select the wallpaper you want to use, and a window will popup asking if you want to set the image for the lock or home screen.
Sorry, I don't use ADW so I have no idea how you set/adjust or if it's even possible to have a separate lock screen image. The native TouchWiz overlay allows this.
