Help Changing locksceen?
So is it possible to change the xperia x10's lockscreen wallpaper? Thanks.
Yeah. But the phone needs to be rooted.
I rooted using the flashtool and installed Ripple Lock.
https://market.android.com/details?id=com.nanoha.MyLockScreen_free&feature=search_result
Just have to move the small circle out of the big circle and the screen unlocks (there are a bunch of other weird things part of ripple lock, like you can use media player controls from the lock screen and open shortcuts to apps from the lock screen....but I turn that stuff off)
Also displays battery power and auto rotates....there are a bunch of other lock screens out there to try from but as most require that you root.
Sorry to sound a bit thick but are you on about that when the lockscreen on you can see the normal wallpaper as if the fone was unlocked?
I use Multi Picture Live Wallpaper (search the market. You have got options with this program to have a different picture on the five differnt screens and also have a screen lock wallpaper aswell.
If this is what you are trying to do i do suggest this app
