changing password on prestige 7L
  • Start date Start date
A
Android Question
Guest
My daughter has forgotten her password to her prestige 7 L. What do I do?
Hello and welcome to Android Forums! :)
If you have either WIFI or 3G enabled, then
If you are talking about a screen lock password, then after a fixed number of incorrect entries your phone should prompt you for the password for the gmail account the phone is registered to. If that doesn't work, shut off the phone, log into the gmail account on a website and change the password using Google's password recovery. Once the new password is confirmed, turn on the phone and try using the new password.
If you do not have either enabled, then I'm afraid you would have to factory reset the device, which would mean that you loose all user data from the phone and have to set up from scratch.
