Changing phones -
kim1349
Hi,
I haven't been on here in a while. I just purchased a new Droid 2 and plan on using it instead of my older Droid 1 (which by the way I was told when I purchased it at the Verizon Store that it was a "World Phone, quad band". It is not.)
Ok, what I'd like to know is what can I do or what is the best way to move all my stuff, apps, data, etc, from the old phone to the new one.
I am in the process of rooting it so I can run the Titanium Backup. Will that do all that I need or are there other things to do?
Thanks
Sparks
Change out your SD Cards.. You should have saved your other stuff to your google account.. That should be able to sync.
