changing settings
Recently my friend stuffed up his phone by changing a setting and he then forgot how he changed it. How easy is it to do? Has anyone had the experience of changing a setting and stuffing up their phone? Should I be worried?
Please forgive me, I am new to android and dont really have much of an idea about what to do
My question is:
- Is android easy to stuff up (like changing a setting and stopping the whole phone)
- If you do stuff it up, is it easy to fix
Thank-you
My question is:
Thank-you
Any settings that get changed can easily be changed back, as long as you can remember what setting you changed and what the previous settings were.
Unless you are planning on rooting (getting administrative access to the file system, similar to jailbreaking an iPhone) then there's very little you can change that would cause any problems.
