changing sim card
  • Start date Start date
A
Android Question
Guest
what will happen if I use a new sim card for my new rezound vs. using my old card?
If you intend. to use lte you will need a new sim. New sims also can give eap network ids if your carrier uses this. Otherwise it wont make much difference. There is no good reason not to have a new one if it's on offer. Normally you can keep your number.
Roger
