Changing system bar shortcuts Galaxy Tab 10.1
lrollo
There are 3 shortcuts on the pop-up system bar I would like to remove and replace with other shortcuts.
Can this be done ?
If so, how ?
Can this be done ?
If so, how ?
If you have ICS v4.0.4 installed on your Tab, then yes you can change them. Just tap the 'edit' button at the right when you hit the button to roll up the shortcuts.
If you still have HC v3.2 then no you can not alter them without flashing a custom firmware.
