Well, first you need to put the mp3 on the sd card. Create a folder called Media, and another folder inside that called Notifications. Put the mp3 in there. Them go to your text messages, hit menu-settings, and change the ringtone to the one you put on the card.
And BTW, the search button is your friend...
