Help Changing the lock screen to default picture...
green1988
Hi. I am trying to change the lock screen back to a default background. The issue is that I once when I first got the phone I changed the home screen wallpaper back to a default background and a small pop up appeared which said something along the lines of "do you want this image to be set as your lock screen wallpaper too?" i clicked on the 'no' option and also i clicked on the "do not display this message again" option too as I thought i would be able to change the lock screen background another time. However now when i am trying to change the lock screen wallpaper i go settings> display> screen display> lock screen wallpaper and it just takes me to my images and photos etc but no default backgrounds. Also when i change the home screen wallpaper it doesnt give me the option to make the image my lock screen background as i stupidly chose not to display the message again!!
I hope this makes sense and I have explained it clearly :/ its just reallly annoying me! has anyone else had this problem or have any solutions?!
Thanks...
hmm.. when i go to the settings/display/lockscreen menu, i see an option to view my gallery as well as Wallpaper gallery, which has the default wallpapers. i dont think that the message that popped up should remove this gallery. so when, on ur homescreen, u hit menu/wallpaper/ u dotn see a Wallpaper gallery?
thanks for replying!
no if i click on lock screen> wallpaper it just takes me straight to the gallery section like it would if i clicked on 'gallery' from my other menus. and in all of these folders none of them have the default pictures in!
maybe its a glitch in my phone :/
hmm i dont think that'll help coz he seems to be missing the stock gallery. well if u really cant find it, the best i can do is this - check out post #7, it has all the stock wallpapers that came with it. create an album in ur gallery and shove those in. if ur just looking to find a way to undo ur mistake, and not the wallpaper itself, i have no idea :D
Hi
How do you save these photos to the gallery please?
Thanks
