Syreth Gracelin
What would be the proper way to switch from TouchWiz to Google Now?
If it's not already installed on the device, simply install the launcher from the play store
https://play.google.com/store/apps/details?id=com.google.android.launcher
And set it to default
I don't need to, but I also don't want TouchWiz happily sleeping silently in the background. I prefer to remove it and save storage space, which that will do, right?You don't need to... just set google launcher as the default and it will do its thing, with touchwiz happily sleeping silently in the background.
No it won't.... as it's stored away in the system bit of your device and so you won't get that space back..I don't need to, but I also don't want TouchWiz happily sleeping silently in the background. I prefer to remove it and save storage space, which that will do, right?
Isn't there any way I can convert the storage to user storage?No it won't.... as it's stored away in the system bit of your device and so you won't get that space back..
