Help Charger hard to pull out?
iTzKPanda
AF's resident panda
I just got my new SgS2 and it's really hard to pull out the charger after its done charging. Is it supposed to be like this?
So plugging it in is easier then unplugging?
I would try a different charger. Compare the two and see what if any differences there are with the resistance.
If you plug it in and unplug it right away is it the same, or is it harder to unplug after its been charging for a while?
Well, after a few times of charging, it seemed to be because the charger and phone were both new so they had to get acquainted a few times before being able to seperate easier. Thanks for the help :)
