charger question
nieltab
Hi,
I have a samsung galaxy s advance, i'm at my girlfriend and forgot my charger. She has a samsung diva, with a charger that looks the same (input= 100-240 V 50-60 Hz 0.15 A output= 5.0 V --> 0.7 A)
I found on the internet that the input is the same, but didnt manach to find the output?
Can I use this charger?
You should be OK, if it is a little more than your charger (minimum .5A output) the battery will get a little warm, if it is a little less, it will just charge slow.
