charger
  • Start date Start date
A
Android Question
Guest
what to do when htc s from t mobile is stuck in charger mode
If you mean that it says it's charging when the charger isn't plugged in, VERY carefully check the charging port for dirt. Also make sure that the center piece isn't bent to the point that the metalpart is touching the outer shell.
