Hi, it will be ok and will not cause any damage, as long as it is a standard 5.0v DC output which all phone chargers should be. The important thing to check is that they have the same, or higher, mA output rating as the stock charger eg. 500mA, 750mA, 1A (1000mA) etc. A lower mA rating will take longer to charge the battery and may not charge it at all if you are using the phone at the same time as charging.
