Probably want to get a USB host OTG cable first then a standard USB cable from the same company since they are very inexpensive cables try to get them from the same company to save on shipping.
If you want to use the N7 in the car for navigation you'd chose a microUSB cable as short as possible and with thicker power wires because of the larger amount of amperage that charging and the navigation app (at the same time) are needing.
Quality mircroUSB cables like these by DeLock have 24AWG for the power wires instead of 28AWG like the data wires.
Such a quality microUSB cable could become handy also at home, if you want you use the N7 while charging.
And if you want just to charge in N7's stand by over night, any microUSB cable could be used
I bought 2 cables and they dont seem to charge as fast as the 1 supplied with the nexus, they work as data cables though which is a plus but im still looking for either a cable to charge or a mains charger.
It is depending of how you charge your N7. If you charge while the N7 is on stand-by, different cables whould not make any difference of charging speeds.
See, the important part is the charger (that plugs into the mains), so you'd use this one which came with your N7 or that Asus (which should be the same ).
Still undecided what to do, that asus 1 is just too expensive, wasn't wanting to spend that much though. Ill see what these 2 cables are like before I buy another cable.
