So I've a Coolpad Note 3 Lite and I've installed CoolUI 8.1 Reborn Marshmallow. Everything's fine except the charging. When i start charging there's no indication and the power button stops working. I have to force restart every time by pressing the power button. The site I downloaded from, they said that the battery isn't calibrated and all I have to do is to drain to 0% and switch off and charge to 100%. The problem will be solved but that doesn't work whenever I install it. I need that patch or fix or the original OS without any bugs.
Link : http://t0la.blogspot.com/2017/11/coolui-81-reborn-for-cp8676i02-note-3.html?m=1
