Root Charging images
Ok perfect, now my next question then is where are some good ones that fit our sequence? Oh and to clarify we are talking about the phone off charging images right?
As in the phone just died and you plugged in the charger and now it shows you the battery. ?
Sorry i dont think this is possible because it is my understanding that those charging animations are within a special partition.
I know they're in the vendor/etc folder the same vendor folder I deleted the social+ apk from only that was in vendor/app. It looks like they're a series of pngs similar to a boot animation, which makes me wonder if they can just be swapped out with ones of a similar sequence.
I might do it on my backup phone, but just got it unbricked and like having the piece of mind...don't have my computer still. I need to find some first so I might try to pull some off a comparable ics 320x480 rom
