Charging note 2 thru pc
  • Start date Start date
A
Android Question
Guest
Hi, I am unable to charge my NOTE 2 thru my pc, when i connect the phone it only acts like a dock to transfer data. Which is not what i want to do. Is there a CHARGE ONLY option in the phone?
Also, how can i take screen snapshots?
Thank you!
Hi and Welcome
The easy one first
Screen shot:
System settings
Motion
Palm swipe to capture - tick the box
Screen shot by sweeping the side of your hand from left to right or right to left across the screen. Image is copied to the clipboard
The phone will be charged at max 0.5amp current when connected to your laptop or pc. This is only % 25 of the charge rate when using the supplied charger which is 2amps. It will charge whatever else you are doing, but at 0.5 amps (the standard usb rating) it may discharge even when connected because the phone is using more than it is getting if under heavy use.
Roger
