HunnieBunnie
This question is slightly off topic. The LG Motion's power corder is in two parts. I realise that the wire portion unplugs from the plug portion so that the wire portion can be plugged into a computer's USB port to charge the phone.
My laptop, a MacBook Air, has only one USB port, so if I plugged the phone into that one USB port to charge, I would not be able to use, for example, the Superdrive, or any other item that plugs into the USB port.
What I am wondering is if anyone makes a widget that plugs into the computer's USB port and thereby allows the user to then plug several different devices into the widget at once to make better use of the computer's single USB port. It would be similar to a widget that one plugs into an electrical outlet to allow several items to be run out of one electrical outlet. I hope this makes sense. It is difficult to describe what I am thinking of.
Thanks.
Thanks.
