Charging phone whilst switched on?
moggie
Hi
May I ask a further question - everyone was very helpful when I first got this phone.
Will it charge when it is switched on or must I switch it off always first? So far I have only charged it when it os off and it takes about 80 minutes to charge to 100% from say 9% full.
I use a 2 amp? charger which did not come with the phone.
Thanks
Yes - it was a refurbished phone - looked new as it had all the plastic screen coverings and it works perfectly. It came with the charging lead only so I use the Huawei charger from my tablet. The charger gets slightly warm (not hot) and goes cold as soon as it is charged if I leave it plugged in. This seems to be ok?
Thanks for quick reply
yep should be fine. charging will always create some heat....no way around that. so things should get warm but not hot.
.....so you are good to go;)
-- Yes, you should power off your phone when charging it. The charging circuitry will be able to function in a more optimal setting when the phone is powered off. But here in the real world we all have other things going on all the time so it's just not practical to do everything in such a manner. Most of us just plug our phones in when the battery needs a charge up, and for the most part that's quite adequate. So don't worry if you do or don't power off your phone, that's a minor point. Just keeping your battery continuously charged up is the biggest factor to help its overall life span.
-- Taking 80 minutes to charge the battery that much is a typical amount of time. Any battery that's in it single digits of capacity is going to take a while to charge up, and it's important to also take into consideration that your phone is over five years old and as smartphone batteries age it's not just that they don't hold a charge as well they also take longer to charge back up. It's unavoidable. (Unless you've had the original battery replaced with new one at some point):
https://www.gsmarena.com/sony_xperia_z3_compact-6538.php
-- Your phone most likely came with a 5 volt/1 amp adapter, that's the default charger that most manufacturers were including at that time. If you're using a 2 amp charger, keep using that one. It's not going to hurt anything and the battery is going to charge up faster than if you use that older 1 amp adapter.
