So are we safe to assume that our charging cords (not the touchstone obviously) for the pre will work Ok with the EVO?
for sure uses mini usb.
The USB cord that came with the Pre should work fine but I wouldnt use the palm charger itself.
ok you mean the actual wall thing where the cable plugs in that has the palm logo and usb on one side and the AC plugs on the other side?
thanks
Micro Usb (NOT MINI LIKE THE HERO)is going to be the new industry standard for the majority of phone manufacturers.... save for apple of course..
all usb based chargers are the same... there usb they all supply the same amps reguardless. thats the usb 2.0 standard i have used the charger from my moto q9c touch touch pro and hero all on the hero and even my generic car charger aswell
BTW, anyone looking for extra usb cables for charging, check out monoprice:
3ft:
For only $0.97 each when QTY 50+ purchased - USB 2.0 A Male to Micro 5pin Male 28/24AWG Cable w/ Ferrite Core - (Gold Plated) - 3ft | USB 2.0 Cables - Micro-B Type
6ft:
For only $0.93 each when QTY 50+ purchased - USB 2.0 A Male to B Male 28/24AWG Cable - (Gold Plated) - 6ft | USB 2.0 Cables - Regular Type
The way shipping works there, it is best to buy a few.
Most USB chargers use a current of 0.5A, whereas the pre charger uses a current of 1A (look it up online). So they all aren't necessarily all the same. Better to check beforehand than risk your phone and assume.
But the device will just draw as many amps as it needs, voltage is what you have to worry about and since all USB connectors are the same voltage you are fine. You can also use a .5A charger with something like the Pre though it will just charge half as fast.
Does anyone know if the EVO will use Micro USB to charge?
Ah, good to know, yeah I knew the pre would charge half as fast with a .5A charger. Didn't realize with a 1A charger a device would just draw as many amps as it needed.
Just for the record that second link is wrong.
here : For only $1.16 each when QTY 50+ purchased - USB 2.0 A Male to Micro 5pin Male 28/24AWG Cable w/ Ferrite Core - (Gold Plated) - 6ft | USB 2.0 Cables - Micro-B Type is the one for the 6ft cable which appears to be sold out. And here : For only $1.34 each when QTY 50+ purchased - USB 2.0 A Male to Micro 5pin Male 28/24AWG Cable w/ Ferrite Core - (Gold Plated) - 10ft | USB 2.0 Cables - Micro-B Type is the one for the 10ft cable. I just ordered 2 10' cables for $6.04 including shipping. As long as they get to me before 6/4 I'm happy.
