Charging Port on Top???
vikingjunior
Personally I think the LG Black by every means is a excellent device by why o why did they put the charging port on top????:mad:
I can only hope they switch it to the bottom for the USA.
I can think of a couple reasons why I would want it on top.
One is, when I use my GPS I sometimes have to plug the charger in to the phone, When I do this I can't put the phone in the holder because the charger goes in the bottom and the holder has no holes in the bottom. Plugging in to the top I could charge it and set it in the holder and see and hear the phone without it sliding all over the seat.
Same with wanting to charge it when the battery is low while driving.
Listening to music etc.
I am use to the power button being at the top right corner of the phone, and would hope that is also where it is on the OB.
If you use the phone while charging it puts a lot of stress on that port. Hence why most put it on the bottom or the side.
There it just depends on how one uses the phone. If you use it for calls while pugged in it's not good, but if you do the other things it is good.
I don't talk much with the phone plugged in so this wouldn't be a problem for me, but I can see how it might for others.
